Which posi unit ??
need boost
got boost? you should!
Staff member
Going to upgrade to 30 spine axles and have been looking at the eaton posi units. Need input guys. Car will be mainly street driven but 2-3 times a year at the track with transbrake launches . There are many different eaton units out there ! Part numbers please on ones that work the best Also what gear seat? Going with 3.42s again but been looking at richmond gears and several others. all input is appreciated! I do not want to run a spool. Thanks Daniel Ray
Not sure on part # but i went with an eaton an got the complete kit an kept the factory gears . Its been working fine for 5-6yrs
I just put a 30-spline Eaton in my GN. Along with 30-spline Moser axles. Also did a TA girdle cover and stud kit.
Just FYI, the Eaton is a large hub and YOU WILL need special carrier bearings for it. I was unaware and ordered the standard install kit and had to order new ones. Luckily a local parts warehouse stocked them. Also be easy with the crosspin bolt. Mine broke and I had to track down a SnapOn truck to get the removal tool. Been working great so far.
Eaton requires that you use conventional fluid with its diffs. I used some Amalie 80w90 my buddy had in his shop.:smile:
I knew about the bearings but thanks for the heads up anyway! What you just did is exactly what I am doing lol, with the cover and all. I talked to a guy at powertrain.com yesterday about aurburns and eatons and I am getting my unit from them. Going with the eaton unit and he said they have the bearings for the carrier. No one has said anything about the gears? I am looking at richmonds or motives. Both are suppose to be excellent sets. Thanks for the heads up on the fluid, I have done bought royle purple so I will take it back and get some regular fluid for it. Still need to add the additive to it though right? Thanks Daniel Ray
without going into a lot of detail
If I were you and set on after market gears--go with Richmond--I had a night mare with some Motives a few years ago with noise. They tried to work with me but to no avail --ended up refunding my $. I have the exact setup you are going for--30 spline Eaton--30 spline Moser --TA cover. I had an electric trans brake a few years ago and let my son have it as I was afraid of busting the posi unit on launches. I did launch with it one season. My son had a spool. From my experience factory gears will run quiter than after market gears. Best of luck.---Lee
Check with Otto's Performance for a price quote on the posi and axles. He gave me a good price, just haven't made up my mind on what/when I want to do.
I just reused my original gears with the new parts. No problems yet. As far as the additive goes, the Amalie fluid I used said it had posi additive in it, but I dumped the GM stuff in it as well since I already had it. That and I wasnt sure of how much was in the gear oil itself. The bearings I bought were $50 so it wasnt too bad.
Same as what Ive heard. Id stick to the factory gears unless they're too far worn or you break one.
