Up to 20 lbs of boost you could use AC Delco R43TS or CR43TS, Autolite 24's, NGK UR 5's
If you run over 20 lbs. of boost you could run, AC Delco R42TS, Autolite 23's, etc.
You guys can open those gaps up if you stop using the stock ignition system. Probably not a big deal on a track car, but the bigger gap makes cruising around a lot better. I've had zero spark issues with NGK UR5s gapped at .040. TR6 ignition module and $60 Silverado coil pack.
