With the new shell, putting 8pt cage in and I was wondering what stall would work with my set up.
TE-62
stock heads
3"dp
2 stacked gn intercoolers
jj 62 tb
razors alky kit
009s
hot wired pump
billit top fpr
trans + with extender
3.5 maf and pipe
tranny I currently have a Red stripe 2800 stall.
upgraded servo
pts shift kit
pts preassure regulator
kevlar 2nd gear band
10vane pump
Car weighs about 3000#s
My last best run was 13.59 @113 with the slicks rubbing all the way down the track. Not Good. MY 60ft was 2.0
Thinking since the trans is out want to upgrade to somthing that is streetable and can handle the power down the road.
Also what stall range?
Thanks for any info or tips
Chris
You can also watch the vid in my sig to see how bad my run was.. I took off at 6 # of boost.
TE-62
stock heads
3"dp
jj 62 tb
razors alky kit
009s
hot wired pump
billit top fpr
3.5 maf and pipe
upgraded servo
pts shift kit
10vane pump
Chris
