Which turbo
CHANCE
No longer a Buick guy!!!!!!!!!!!!!
look at my sig and tell me what you guys think on inj and turbo ideas and nothing to crazy like $1700 watercooled turbos
can i use the stock computer with the 60# injectors
Yeah Full throttle and others sell them. I think they are the High "Z" ones. That way you dont need a modded ecm. If your ecm ever takes a crap, its easy to find another stocker.(Razor gave me this advice) You have quite a big cam there, are your heads ported? The 3000 stall may cause slower spooling on turbos like the 45A, PT-67(non-bb). Does spool up time mean alot to you?
yep my heads are ported as much as you can get
were can I get a 67BB? also whats the full name for it? ie HP6765,HP67HPQ so it will be easier for me to find one
To tell you the truth I can remember it's been so long, that cam is going to come out and be replaced with a roller when I start my restoration.
His OP said nothing crazy like $1700 turbos...bb67 turbos are just that-more.
A 67 in a std bearing will be like $1200 shipped. Thats a lot of turbo, but your converter will be a bit tight for it. 3200-3400 would be about wright.
How much you want to spend? Just buy the biggest turbo you can afford. Keep in mind your converter stall. You know your cam is huge, but I would leave it and see how good it runs with a big turbo.
How about a 6262s? Someone on here is running hohn tens with a unopened stock block and 3000 stall?
Iron heads and 224/224 in a 231 = no no. 60's for an engine that can swallow a 224, lol. Lol on the turbo recs without attention to the converter. My turbo rec is a 76HPS 4 bolt with a PTC 9.5". 80lbs/hr injector 76 HPS, and enough spring will make 9 sec power if you keep that cam. Id personally get rid of that cam and buy a journal 6176 turbo and a 9.5" PTC. Nice 10 sec streetable stuff.
Thanks for the advice guys, also like I said in an earlier post I'm going to lose the cam and go to a smaller roller cam
3 years and you stiil have yet to find one.:tongue: You swap the cam yet?
First thing I noticed was cam was too large too, saw you're swapping it out, 210/215 Roller has been nice for me.
With your current mods, the biggest new turbo would be around a 62/62, if you upgrade the intercooler and are looking to push 30psi at the track, then consider the 62/65.
jasjamz,
Not yet I'm deployed right now to Afganistan, but when I get back I'm going to start my restoration on my WE4, so I have been building a list of things I need to replace.
