Which Water for Cooling System?
HighMileage
Albany,NY
I just drained my old coolant/water mix. It looked ok but was old. I filled with water…ran up to operating temp….drained. Repeat until clear.
I use Conventional Green and RMI.
Q: Which water? Distilled? Filtered spring water? Chlorinated tap water?
Thx.
I would do distilled but I'm kinda cheap so mine usually just comes out of the hose unless I plan accordingly.
Thanks for the reply. I heard distilled attracts minerals and causes corrosion. But who knows? That’s why I’d like to see what others use.
You might be right. I guess i'm ok with the hose water.
I knew I heard something about Distilled not being good. Only good for batteries. I think my dad said it 20 yrs ago.
I’m leaning towards the filtered spring water at Walmart. Comes in gallon jugs like distilled. They have Nursery Water,too. I wonder what that is.
I know its frowned upon for being a waste of $ and stupid & lazy & all that crap but I use 50/50 premix.. I just trust whatever water prestone is using is good, another benefit is I periodically drain my radiators & refill with new & everything stays 50/50 (New England) without breaking out the measuring cups & science lab beakers.
I use a simple coolant tester. Just the right amount of Conventional Green,RMI and water for 60-70%.
Just searched it, prestone uses demineralized water. Then searched that vs distilled for some interesting reading.. distilled is go to popular opinion same way most think 160° tstat is the only way to go.. till you start reading
Found this about distilled:
“But the problem is that when water is distilled, or “stripped,” of its minerals and impurities, the resulting solution is composed of chemically imbalanced “ions.” This leaves distilled water “ionically hungry,” so it will actually strip electrons from the metals in a cooling system as it attempts to chemically re-balance itself”
Walmart sells purified water for $1.37/gal. That ought to quinch your OCD just fine.
"A prominent example is the production of Bottled Purified Water, which involves using purification processes such as distillation, deionization, or reverse osmosis to remove impurities. " - from aquascience.com.
It looks like I’ll be going with the Walmart Filtered Spring Water. I don’t want something that’s going to be looking for minerals in the cooling system.
That statement is BS.
Distilled water (while still not ultra pure which is an expensive process) has (virtually) no ions which is a good thing. Pure water will not conduct electricity which means it will not promote galvanic corrosion between dissimilar metals (iron and aluminum). It will also not leave deposits from the hardness. Additionally it will not have any dissolved elements which will eliminate deposits.
The worst thing you can due is put chlorine in the system. Chlorine is a powerful oxidizing agent.
Soft water is better than hard water, and no the softener does not replace the hard water ions with salt ions, you end up with a small amount of trace salt because salt is used to recharge the resin bed. The resin bed removes the ions. But the softener does remove dissolved elements, only ionized chemical compounds.
Distilled water, with the proper additives is good. The additives promote heat transfer, stop freezing, and inhibit corrosion. i.e. a good antifreeze with distilled water. Since pure water is an excellent solvent, the additives also inhibit any metal becoming dissolved in the coolant.
I think your good. You don't want to use straight distilled water or demineralized without an additive. With the proper additives it is the way to go.
Again all these theories & variables.. I figure let the dang coolant corporations do the engineering but ya if your going for something other than 50/50 you'll have to make a decision on what to mix with.. it's Probly like the old man that lives till 102 on bacon eggs cigs & hi-balls u might be fine taking a wizz into the radiator.
Hope you don't mind me sharing your secret @Chuck Leeper
Thx for the reply. I was just going by this website:
Is this the same Nigel that i met at the Valley about 8 yrs ago? I was over at your house a few times. I went by the other day on the way back from the Valley and saw your car out but didn’t want to just drop in….
Branch water and a qt of horse piss and we're good to go!
Now, if that "horse" has been drinking bourbon in the evenings, would this raise or lower the Bowling point of the coolant?
Asking for the horse.
Same same, how's it going? If your driving by feel free to drop in. I have not been up to valley in a while because I don't have a roll bar, and last time there they called me on it.
