Sixxshot87
- Sep 3, 2008
Has anyone ever seen steam and/or white smoke come out valve covers due to condensation in the engine from a pcv system being replaced with a filter and condensation getting into the engine. The "steam" happens imediatly even when the engine is cold started and coolant temp is only 90 degrees but is only visible when you rev up the engine.The reason i say steam is the "steam" does not linger around like smoke and it happens like i said when the engine is cold started. And on a side note it is humid enough around here to put condensation behind my headlight lenses.It Comes out the pcv hole that the filter is on and oil fill hole when i take the cap off. Coolant is green as new and oil is not milky and appears just changed.Elaborate....
