Who is using an A1000 fuel pump?
John N
I'm mounting up a fuel cell in the trunk and an A1000. I am thinking of mounting the pump under the car on the driver side. I would like to know how those using this pump wired it, mounted it, and if an accufab FPR on the stock rails was too restrictive for it. Thanks!
We have done many of these installations.
I will be glad to give you the info if you want to call. I do not have the time [or patience] to type a response.:D
Ams1000
I have one under my car . It is mounted on the d/s I used bolts that went through the fuel cell strap to hold it then drilled two more towards the d/s. I used my hot wire relay for power and ground to the new pump. I have around 700-800 hp and no problems so far. I use the factory regulator and a 1/2" fuel line for the supply line. HTH:cool:
That just about answers it all. I wanted to use the hot wire relay as well so I'm happy that works out.
