Who modifies stock D5's to raise stall?
OneQuikV6
Automotively bi-curious
Looking for someone who can modify a stock D5 to raise the stall to 2800 or so. I have an extra D5 that worked fine when removed and thought it may be cheaper than buying new. After the new trans install, $$ is tight. Anyone?? ;)
You are playing with fire....
Do the right thing and get what it is you really need. Loosing a D5 is a disaster most of the time. Not recommended
Gotcha, Bruce:)
If I was wanting a simple upgrade to the stock D5, what would you recommend? I'm really not needing a high dollar convertor at this point due to $$ contraints, but would like to have a higher stall unit. I know your busy, so I appreciate your help tremendously!
