slimtastic
yea dude...I rock
- Aug 9, 2002
hey all, ive got a few speed items im trying to get rid of. its too heavy on the wallet to play in buicks right now so im parting out my car.this will be the first of probably 2-3 more threads im gonna have for selling parts as i get around to removing them. so if you are looking for somthing i didnt post for sale or whatever just let me know. all of this equipment is well under 2000 miles old.
T/D roller rockers 1.65 ratio 400$ shipped
TA-64. precision built comes with a .63 and .85 housing (the .63 was ceramic coated by Polydyn coatings in houston TX.) also comes with stock boost actuator and hd actuator. 1000$ shipped
83 lbs siemens injectors and accufab adjusable fuel pressure reg.(good sonic bath and o-rings recommended) 300$ shipped
stock 86-87 intake ported out to accept felpro 1200 intake gaskets. had all intake runners coated with teflon based airflow coating from Polydyn coatings, and the bottom of intake was ceramic coated. 230$ shipped
champion racing alternator bracket, for removal of power steering and ac. will include the right sized belt for appication. 115$ shipped
accufab upper racing plenum and 70 millimeter throttle body. ths also comes with the correct rjc power-plate, a rjc billet iac relocator, billet vacume block. the power plate and the upper plenum have been coated with the same Polydyn airflow coating as the intake. 500$ shipped (comes with tps, and idle air valve)
ATR dr side header/ G-Body parts crossover/stock pass side header with light cleanup work done to inside. exhaust wrapped and comes with used copper exhaust gaskets. 250 shipped
factory service manuals, both of the thick ones, i might have the third smaller one too but there was no useful info in it so i lost track of it. 150 shipped.
id like to keep all transactions pay pal based if thats ok. sometime tonight or tomarrow ill post up pics of all this stuff, and later on down the line ill be posting up other items so if you have anything partcular you might be looking for(3.5 dp,fast seq, pts trans,aluminum driveshaft, double pumper, ect) please let me know.
