Who's ready for some 3800 power?!
What's the scoop on this? I have a 3800 with a flipped LIM on my engine stand right now! I just got done reading this whole thing and didn't realize that there was so much 3800 enthusiasm on turbobuick. I haven't figured out the accessory portion of my build yet, so I may be PMing some of you guys.
As you're aware the blocks are stronger than our 109 blocks. If I hadn't started my 109 rebuild I would've opted for a 3800 build. I may still try in future if I have the funds and can get my hands on a decent roller. Blocks are not an issue, I have an 96 and 97 block that have been machine. The 97 was aligned honed with ARP hardware, studs and fasteners for the cross-bolted mains. Good luck.
Thank! Yeah, I'm sure if GM put these engines into a sporty American RWD car to begin with, the Buick clubs would be a lot stronger today. Oh well! It's not too late to show everybody what these underdogs are made of.
Just wanted to finish this thread from years ago for people that don't follow me on Facebook .
So a slower day thought I’d share a little dyno experience this last Saturday at Powerfab speed. My 87 T with the custom 3800 series 2/3 engine with a smaller Precision 6466 Gen 2 T4 on it. Finally got a base dyno on it after many years of working out bugs. Not bad result for first time out with limited time. At 27 psi did 621.5 HP at only 6200 rpm with low timing. 93 octagon with M1 injection. Much more to come. The power keeps climbing I honestly think it will hit 700 at the tire with more seat time. A larger turbo would make a lot more power but this is a street car. Thanks to Cameron Arp for all the help on the DYNO and Powerfab here in Houston for the Dyno Use.
Future plans is turning the wick up and seeing what the 6466 will do and possibly throw my 6870 4 bolt from my other car and see what it will do.
There is a company in Australia that makes a Holley Ram type intake on an Ecotech intake. Like a holley hi-Ram. Like to try that as well. Anything over 700 at the tire is a win. I'm sure the engine could make some serious power . A lot of work over the years with multiple set backs and life. But it was worth building.
It looks right at home. Congrats, talk about sticking with something, that's tenacity.
This gives alot of options for the n/a cars.
Had some Machine shop woes over the years and life got in the way . Plus this was the 1st 3800 or 3.8 buick with a Holley efi on it according to the Holley engineers I worked with at Holley to get it running. Long process!
That looks really good in there. Most excellent!
Whoa this is unique, I don't wanna read 22 pages but there must've been a good reason to ditch the 109, maybe the 3800 is more reliable etc?
The torque comes in really late, like literally climbing past 5200rpm, are you ramping boost in later on purpose or is it not all in until like 5000rpm?
I'm sure there were unique headaches you pulled off alone, congrats 👏.
Torque coming in late is because how I was hitting it on the dyno. Eased into it until 3500 rpm. It is higher.
Have you searched for 109 or any 80s 3.8L engine parts lately? Plenty of these 3800 engines out there in the wrecking yards now. The bottom end is light yrs ahead of the 109 and the cost from a yard isn't unreasonable. Lots of info in these 22 pages for those who want it.
Thanks for the update. Awesome results. Many videos on YouTube of our Aussie friends squeezing 8-900 hp out of these engines.
Yeah I know a couple guys there making over 1000 at the tire. That one car that hit like 1400. Crazy.
Id think if I install the my 6870 on it . I think 900 would def be attainable.
I used to drive a 3800 powered impala fleet car for work. WOT to redline all the time, every day for 100k miles. Couldn’t kill that motor. The 4t60 trans was another story.
Yes, the 3800 series II/III bottom end has decent size main caps and they are cross-bolted as well. Some dudes in Australia made between 800 to 1000 whp with the stock crank and main caps. They could have went further, but I think they were lifting the heads.
I have fully machined 3800 series II block, along with a set of forged rods I bought from GBGN1. In addition, I was able to get a brand new nodular iron crank. The block is bored 0.020 over. Dave Roland did the machine work for me.
Tons of great info in this thread, I’m about 10 years too late though. All the pictures aren’t available now…
I daily drive a 79 cutlass with a 3.8 and am gathering parts to drop in a L36 with a turbo, or a l67. I will use a 700r4 so I can easily keep the stock speedo. I have both l36, and l67 engines on the stands hoping I can mix and match accessories to make the swap easier.
This car is my year round daily, so I’m following the KISS method. I think using the L67 would be the easiest path. I’ve seen it mentioned of using 4th gen headers, will they fit without too much trouble? Will I need to move the starter to the other side? I assume I will need to use the l36 oil pan from the f body. I saw it mentioned that the frame had to be notched to use the f body a/c compressor?
I have no idea on the headers, I had custom 304 ones built and overall work really well. Yes f body pan and the drain for turbo gos to it as well. f body ac compressor will hit ,That was the consensus when a few people did the swap. I did it totally my way and incorporated the 87 GN accessories. but there is some fab to making that all work. Easiest would be to retain the 3800 accessories and notch the frame. Good Luck
"Have you searched for 109 or any 80s 3.8L engine parts lately?"
I've found every part for along with my 109 I've needed, can't think of any new part for a 109 I couldn't find since 1997. That's one of the great things about our platform, new parts are available.
If you're referring to only using stock 109 parts then sure, probably a real challenge but it's a risk using 40 year old parts in most of our engines making 600tq+ anyways. 6262 turbos are now 900hp+ capable and that's only going higher with every new evolution in 5 year blocks now.
3800 seems like a nice option and keeping it in the BOP family. Thanks for the thread, learned some new thing in here.
I'm glad you have found everything that you have needed for your 109. Yes the inability to get a roller cam for 2 years sucked. Blocks are getting more scarce all the time as well. When I started my project with this all the stage blocks were drying up. This was just an alternative to going LS, if you'd read the thread I explain this. This motor is superior in many ways than a 109. The block has attributes from a stage 2. One piece rear main, cross bolted main caps, far superior oiling system to name a few. Ive got fast 109's as well. So I'm not biased .This was having something no one else has done the way I did it.
