dentmasters01
- Apr 13, 2004
ok, looking to put new upper and lower control arms on the car.....upper and lower adjustable....why adjustable? what does each do and do you need both ??
SignUp Now!I assume that you mean rear upper & lower control arms?
Adjustable uppers allow you to dial in the pinion snubber to the correct angle for drag racing, and will allow some adjustment of centering the rear axle under the frame.
Double (fully) adjustable will allow you to make those changes without removing either end of the upper control arms to rotate either frame or axle side.
They cost more & look kool to your mechanic.
Unless you are a drag racer or have pinion snubber angle problems non-adjustable uppers will work fine & save you some money.
Lower adjustable rear control arms are pretty much a drag race only item, and there is not much of a selection of those, which would imply to me that not too many peeps use them.
I bought BMR double (fully) adjustable rear uppers with the spherical bushings at the frame side when I replaced my stock set-up. Not cheap.
Global West lowers with spherical bushings at the front & Del-A-lum bushings at the rear on mine, not cheap either.
I am sure that Brian at GBodyParts.com, Paul Ferry at HRParts&Stuff or any one of TB.com's fine supporting vendors/suppliers have both non-adjustable or fully adjustable rear uppers & a matching set of non-adjustable lowers at very reasonable prices.
Help support the turbo Buick community and TB.com by supporting the suppliers, vendors and / or turbo Buick Specialty shops that are TB.com Sponsorship Team members.
HTH
-------------------------that about covers it, for an old fart, you still remember well!
so whens the next get together?
are you comming to WCN in Phx?
Thanks for the good info!
cruzn57
If you are just getting ready to start modifications you might want to consider Paul Ferry @ HRParts&Stuff's super rear sway bar which I have heard works exceptionally well and comes complete with adjustable upper rear control arms, I believe. Do a search on this item, I have heard greats results from this rear sway bar set-up, both for drag racing & street use. Most peeps attest that they removed their front sway bar with this set-up. I run stock front sway bar with a 1" global West rear sway bar. i believe with very good results.
I posted this while you were posting yours so I did not have a chance to read your post regarding currently having a GNX reqar suspension. If that is a true GNX or even a replica GNX suspension I would think twice about removing that as that adds some "Charm" to your car, and for what you are going to pay to exchange the two suspensions, I don't think that you will gain enough to make up for the cost of the swap. If you do replace the GNX with a standard set-up, even a high performance expensive one, I don' think that you will gain that much, maybe some improved cornering ability, as the GNX suspension seems to work best in a straight line. HTH
