Why alcohol instead of water?
  • Thread starter Thread starter FastGSXauto
  • Start date Start date
I 'm skeptical of your source at Aquamist
Dont be. His name is Richard Lamb, and is either one of the key engineers on the project, or, is a principle of the company...I havent come right out and asked him, but his technical knowledge is broad, and his product knowledge is even greater...Since he says that everything hes told me is ok for public consumption, I'll enclose a short excerpt from a recent email he sent on this subject.
>>what are the chances that they use the one and only viton seal that swells in alchy? Sometimes people will say anything to impress you, or get you off the phone. Rather than simply say "I don't know", some reps will dump a load of B.S. on you. <<
First, we dont talk on the phone...Only via lengthy emails. For some reason, he sees a kindred spirit with me, and therefor often goes into great lenghts on some of these subjects. And, as I said, hes not a 'rep', per se, except in so far as the fact that he does represent the company, as does any principle. Ok, for the excerpt, see your PM.
Paul, I decided to post the E-Mail you sent to me. It's plenty obvious that you are talking to someone in a position to affect changes in the product design. It's pretty cool you were able to supply him with the Dupont link, and how willing he was to improve the pump!
This will become an excellent addition to the supplys available to those willing to cobble together there own alchy kit. Good job guy!! :) :)
Turbotim,
heres a couple of excerpts you may find interesting. The first explains a
bit of history, and the second comments some on the seal situation:
"Hello Paul,
Thanks for the link. We have been using Shurflo pumps for number of years
already mainly for high flow applications - truck racing and tractor pulling
is very popular in Europe - we supply them with shurflo pumps. I have no
problem recognising that their pump flows almost three times as much as
ours.
We developed the Aquamist water pump originally for the Ford's works rally
cars and they wanted a pump that weight less than 1 kg, Shurflo pump weighs
2.7kg and the Aquamist pump weighs 0.85 kg - in 1992, it weighs only 650g
!!- using aluminium winding instead of copper + few others lightening
tricks. The price for the pump was UKP 1200.00 each !!!.
We modified the pump for volume production in 1997 - bring the price down to
lees than 300.00 UKP - weighs slightly heavier. At the time - all private
rally teams wanted to use our pump instead of the shurflo, purely on slight
weight saving - means a lot for racers.
We did consider using the Shurflo pump for the aftermarket but most tuning
companies and the end users prefer to use our pump and willing to pay more -
perhaps it is just a matter of owning a piece of precision machined
component instead of a plastics moulded, high volume industrial pump - at
the time, flojet was another makers of diaphragm pump.
Round about the same time (1994) - Carroll Supercharger In New Jersey
marketed a water injection system based on the Shurflo pump. Rather
following the trend, we went ahead marketing our own pump despite the high
cost. We have come to learn that a few years later, we found out that we may
have achieved better sales in the UK than Carroll in the USA. We realised
that most of our customers liked the quality of our pump and don't mind
paying a bit more. It will be unlikely that we will stop making the present
pump and start using the shurflo for the aftermarket - we are current
supplying seven of our the eight works team of the WRC rally cars - we can't
really stop - accounts to 15-20% of our sales yearly.
It would be interest to found out the truth why people buy our system,
perhaps you can ask a few questions for me on varies boards. I really like
to know. There is just one little point on the aquamist pump's effect on the
water droplet size - the piston action creates a large spread of droplet
size - 30-80 microns on one single stroke. perhaps the range of droplet size
gives a better overall cooling coverage from the nozzle to the combustion
chamber - I am just guessing.
One other story from the history book - it was quite interesting to heard
from Carroll in the mid 90s, stating that their WI system pumps over a litre
of water into their customer's engine, I was stunned to learn that - we were
supplying Rolls Royce 's 6.7 litre Malsanne turbo and only pumping some
250cc/min of water to do the job of raising the boost pressure from 0.7 bar
to 1.2 bar !!!
Anyway, haven't really answered your questions.
Richard "
and
"Hello Paul,
Thanks very much for the link to Dupont.
A wealth of information there and I went through almost every link that
gives me the information on swelling - I may not have collated my thought
together yet - at present I am none the wiser after reading through the
articles.
The information we published and written on various emails regarding the
effect of alcohol was based on actual reports from our customers over the
years.
It has been found that de-natured alcohol (Ethanol) does contribute greatly
to the swelling of our valves. Ethanol has a very distinctive odour, easily
recognised by smell. Over the years we have been advising our customers to
avoid using windshield addictive that smells and diluted ethanol.
We also run tests at 0C, room temperature ~25C and 100C. We put all the
rubber components into a specimen bottom at concentrations between 25 to
100% at 25% increments. We used three alcohols - methanol, ethanol and
iso-propanyl.
The rubber parts are measured very three months - we used a range of gauges
to measure ID, OD and Depth. The test was consist with the advice given. We
started these tests in August last year.
Just to be absolute clear that our seals are made from viton and nitrile,
the two floating valves are made with NBR. Only three components are
critical to the operation of the pump: 1, 2 and 3 -marked by a red arrow.
Once the two valves and the o-ring seal are swollen, the pump can no longer
function properly especially number 3 - the all important floating valve,
responsible for priming and ejecting. The problem is reversible when clean
water is used to dilute the alcohol absorbed, providing the problem is
noticed early enough, normally pressure lost is the first sign. the o-ring
seal suffers from excessive wear - not too critical. None of these component
is expensive, the main cost of repair is the work to dis-assemble and
re-assembling the pump.
Some good news. We have decided to change the seals and valve material, it
has been good so far, we now have seals that run up to 75% of methanol, yet
to determine the result on iso-propanol and ethanol , I don't see that we
will have the new material in place for production and shipping until the
end of
this year. We still won't approve any user to run more than 50% due to the
prolong/accidental fume inhalation and fire hazard during dispensing and
mixing. We will put warning labels on all our systems before announcing that
our pump is compatible with alcohol. Finally, according to the Dupont
recommendation, all the rubber materials we used seemed to be OK for use
with any alcohol - somehow it didn't quite work in practice. Dupont also
have many types of Viton - we just don't have the time to try them all.
Anyway I will keep you informed of our progress. You must remember that our
system was originally designed for used with water only and only a small
amount of methanol is used in cold weather conditions. I see very little
point using alcohol as fuel enrichment from as single nozzle, in colder
weather, the droplet size will be large enough to cause uneven alcohol
distribution to the cylinders, leading to fuel starvation on the front
cylinders if the inlet manifold is the front entry type.
Regards
Richard "
Sorry for the length, but I sense that you find this stuff interesting!
Paul Elliott
There are several elements to WI.
1) the water injected directly effects the reaction in the combustion chamber. Methanol at that stage is just a hydro carbon like the gas is. So it's just along for the ride as a fuel adder at that stage.
2) You can enter Aly/water in two ways,
a) atomization
b) vaporization
Atomization is done by shearing the fluid with an orfice.
Vaporaization is done thur absorbing heat.
Alky is better at absorbing heat quicker then Water. So that alky part is dual role, for charge air cooling, and as a fuel adder.
Water is primarily an anti-detonation element.
With that said, you can figure out where you want to add the mix, and what gains you'll get with what you do where.
BTW, for interesting WI models to look at Tractor Pullers are seriously into WI. ie on my friends we squirt a gal in 30 secs.
250 PSI thru some tiny nozzles. Test firing the system into jut the air, generates huge clouds.
Also, lots of the fuel being added in turbo'd motors is for in cylinder cooling. Using water PROPERLY reduces the fueling needed, for a given HP level.
.If I use 91% alky with that mix instead of the 70% I get knock.If I run more the 50% alky I get knock.If I mix heavy on the water I don't get any knock.I have no idea why it works this way
This whole thread sounds as though Aquamist wrote it... Unlike most guys on this forum, Aquamist is a firm believer in water predominant systems. They would say the reason youre getting knock at over 50% alcohol is that the alcohol is releasing heat as a byproduct of its combustion process which water, naturally, wouldnt incur.
>>So my question, why are you guys using alcohol instead of water? I really want to know if I am missing something.<<
As a user of the Aquamist system, I used to believe this also. Water in theory will cool the chamber better because of heat latency. But, here's the problem. Alcohol is needed to aid evaporation. Its been stated that while water cools the chamber, alcohol cools the intake. But I think the main reason alcohol is used can be seen in this statement from Aquamist:
"But for bolt-on system that requires a great deal of inlet cooling thus injecting a great deal of water for cooling, it is necessary to add alcohol to reduce the heat lost within the cylinders. Rule of thumb. If you run greater than 15% of water of fuel, it would be advisable to add alcohol to re-claim any power loss due to over
watering. Excessive alcohol will lead to onset of detonation as the latent heat is compromised by the heat energy released by the alcohol during burning.
Latent heat properties:
Water: 2256 kJ/kg
Ethanol: 904kJ/kg
Methanol: 1109 kJ/kg"
We can see a couple of things from this statement...first, when injecting the kinds of quanity we're seeing on this forum, it says that alcohol is necessary to use alcohol to offset the heatloss caused by the water in the cylinders...See, you want to loose heat, but not too much at the wrong time! It sounds like a contradiction, but its not. They say that normal water injection amounts are from 8 to 15% of fuel...IN my case, Im using a single 1mm nozzle, which flows 330cc/min, which in my 400 hp M3, amounts to about 17% of the gas used. And thats just a single nozzle. What about guys here, with less HP, who are using from 2 to 4 nozzles! Theyre running like 4 times what I am...Clearly, water alone would douse the spark, cool things too much to build boost smoothly. So, in these quantities, the alky is needed to facilitate things...Why not just run less water, and then be able to dispense with the alcohol? Because greater cooling is desired. Thats why Im running a 1mm nozzle instead of a .7mm nozzle, which would probably be ok with just plain water. I have a centrifugal Vortech blower, pounding out 11 psi on an engine with a static CR of 10.5:1, with no intercooler! Clearly, I need the cooling and knock prevention water/alky provides. And I need alot of cooling...Therefore, the alky is needed to 'help' the water do its thing. Coat your hand with methanol and wave it through the air...Do the same thing with water...Which feels colder? What effect do you think the two fluids will have in your intake?
Case closed. But clearly, this is not a simple problem, and there are no simple answers. Timing, amount, boost, engine type, and so on all effect the final solution.
