novaderrik
- May 12, 2004
i haven't actually driven my car regularly for about 5 years. when i parked it, the trans worked fine- went into gear right away, shifted thru all gears, torque converter locked up when it was supposed to. it just leaked out of the front seal from time to time when it was parked, but never while it was running.
2 summers ago, i moved across the state. drove the car onto the trailer to haul it here. took it for a drive around the block, and it went thru all gears. shifts were a bit soft, but this trans is out of a full size Olds of some sort and has always done that. it's just a temp trans until i can get the original one rebuilt..
last summer, i needed to move it out of the garage so i could clean under it, and it took forever to go into a forward gear after adding like 3 quarts of atf to replace the stuff that had leaked out of the front seal while it sat. a quick drive around the block and it wouldn't shift past 2nd gear. went right into reverse immediately. i put it back in it's spot and left it there until last weekend.
when i started it up, it was about a quart low of atf- i topped it off. it wouldn't go into any gear. so i dropped the pan and found some black stuff on the bottom of the pan and all over the filter. it wasn't gritty, it was just like black oil. a new filter and fresh atf, and it goes immediately into reverse but never goes into any forward gear no matter how long you give it.. i was really hoping that the fluid/filter swap would work good enough to drive my first born child home from the hospital in it sometime in the next couple of weeks.. oh well, the kid comes home in a 2010 Impala, i guess..
so, what's going on here? it can't be anything mechanical from just sitting, can it? something hung up in the pump or valve body, perhaps? also, why does it drip atf out of the front seal when it's parked? it will suck all the atf out of the pan if left long enough. it has never leaked a drop while running, and sometimes it will sit for weeks without leaking then one day there will be a quart of atf in the drip pan i keep under it...
