Why so Low ?? My 02's!!
RUQWKNF27
Well lets start with what I have New Siemen 72"s . Double Pumper with main pump hot wired . " They work , verifyed with air hose @ hot leg solenoid to 2nd pump". @ 21 lbs WOT my 02"s are around 740-750. I am running a Denso Sensor. A guy on the board told me that he has seen problems with theses showing low 02 reading but not had the time to test that theory yet against a new AC sensor I have.. A while back when got to around 15 lbs the motor would like stutter real bad so I replaced the Reg an that fixed that. I think the ball may have been sticking in the reg.. Man that would have been a nice way to say bye bye to my motor.. I have a Extender Extreme chip from Mike could it simply be that there is not enough fuel in my chip. As I do have the translator Maxed out to 14%. An yes my reg is set to 45 lbs vacumn off. When I went 11.00 @ 124 car was popping @ the end of the run slightly had C-16 in tank an saw I had a 02 reading of 746 so I put it on the trailor. Figured that was a smart move.. I'm gonna test another 02 sensor also I have another fuel gauge I want to try just in case but this one is new so who knows. any ideas guys??
Hi,
You're confident that the entire ignition system is up to par? If you are running a 10 second car, this is doubly important. Do you have an egt sensor installed? High temps would indicate lean mixture. I don't think you can really screw up your motor by running it too rich, but understand your concern.Better safe than sorry! Finally, what do you think o2 should be during a pass? Mid .7 volts is fine for my car, but then I'm only running a 13 second vehicle. Are you getting knock?That can mess everything up, as you probably know. Good luck with your trouble!
Have you had a problem with a chip before not having enough fuel, therefore you had the same scenario as me?? Is it rare to have this problem??
