I have been running the TTA with the electric cutout open now for about a month. When put up on the lift, I found that the butterfly had somewhat of a thick dry black carbon. I drove the car for a few days with the cutout closed and the top of the rear bumper had a very fine layer of black carbon.
What is causing this and how to fix ?
Here are the mods
Alky kit
TT chip for alky
30 lb injectors
Scanmaster
RJC boost controller
RJC power plate
160 thermostat
Running 20 psi boost with cutout open and 18 with it closed.
Using Denatured Alcohol and have been adding 100 no lead gas at a rate of 50/50 meaning for every gallon of 93 I add a gallon of 100 as a precaution.
42 FP with line off
Alky dial setting between 4 and 5
BLM 127 at hot idle
O2 change at idle and generally when I do a recall on the scanmaster after WOT through the gears, I get 0 knock and O2 readings generally around 850 to 870
AF 05
Here are the mods
Alky kit
TT chip for alky
30 lb injectors
Scanmaster
RJC power plate
160 thermostat
42 FP with line off
BLM 127 at hot idle
AF 05
