SignUp Now!Originally posted by gndemon
What did it take to do this much damage? Just so I know what not to do to mine.
That's ok high 9's will be good for me. For at least a mouth or 2Originally posted by azgn
I think mid 9's at 143![]()
Originally posted by KLHAMMETT
Carnage consists of the block,crank,2 rods, a billet roller cam, a set of roller lifters(most are stuck in the block) and a complete set of intake valves.
This was a girdled 109 sith steel mains
Originally posted by CallMeMud
Just curious why the edges and beams of the rods look rusted or brown? I honestly haven't seen rod failures in these motors but I am learning. What rod options are there? I thought Eagle was working on it but haven't checked in a while.
Does it look like it got hot down there to you?Originally posted by xlr8ngn
That brown is rust. If you look at the bearings, you can tell if it got hot. Just talking, that is why race motors and street motors have different clearances. A race motor has more clearance, because friction causes heat, and heat has to be taken away from the bearing. It is carried away with the oil, and the larger the clearances the more oil flows and the more heat can be carried away. If you have tight clearances, the flow of oil is less and heat can build up and cause a failure in high HP applications. Again, just talking.
Looks like the crank was externally balanced. The rod beams are polished. Looks like some weight was removed from the crank to balance, so must be light weight pistons. I can't tell, but it looks like some of the main webbing may be polished a bit? Any details on the build?
