GN87Mike
- May 28, 2001
I'm moving my wide band sensor from low in the down pipe to 8"-10" from the turbo. I am trying to go through the radio antenna/power antenna grommet so I don't have to drill a hole. I can push a steel wire through the grommet as shown here.
I have not been able to see the wire on the other side looking down where the antenna/ power antenna cables are visible no matter how much wire I push through.
I can't figure where the wire is going. I have tried different angles and nothing works. Do I need to take the bottom fender bolts out like I was replacing the power antenna to be able to find the wire or is there an easier way? Anybody who has done this please tell me the trick.
Thanks,
Mike
Thanks,
Mike
