Wide journal crank
Does your goals take you past the strength of a narrow journal Cat/Forged chinese crank? I’m not trying to rip on your budget, but the power handling of a wide journal vs. narrow journal is a little debatable depending on your goals.
No it doesn’t, what I am hearing is that then it becomes an issue with rods due to the on center block
I have a new BMS 3.4 and 3.5 stroke wide journal crank 2500.
Located in Caro, Michigan
3.5 crank is a 8.90
3.4 cranks we have are all wide journal
