Wideband and narrow band conflicting....
Apparently I've had the settings in PL wrong the whole time I've had the wbo2....went back and looked @ some logs from my other car and the narrow was 770 but afr was 11.65....had no knock, sohow do you know when to quit?
Sent from my DROID2
That's where I'd stop. At the dyno with race gas, I'll run it lean @ 11.5 AFR and man does it pull with no knock. Don't push your luck any further though. Most recommend 11.0 or high 10s as it's safer if/when something goes wrong.
So if afr comes around to 10.8 @ 22psi, does that mean it's just all she's got?....or can I add fuel to increase boost or will it cancel each other out? Also, when do I add or subtract timing?
Sent from my DROID2
you might want to buy a denso o2 sensor because the ac delco are crap because they are made in china. there is a thread on this. my ac delco is reading lean in the 500's and the denso is reading 800's
Thanks for the heads up, when did they start doing them in china? The one I put in I bought in 2004, had it on the shelf. Which denso o2?
Sent from my DROID2
