Wideband Sensors?
2 QK 4 U
Banned
How long do the wideband sensors last running 110 race fuel?
Also is there a better WB sensor available other than the Bosch 17014?
Thanks,
Jason
straight from the manual.
Wide band oxygen sensors – like the one shipped optionally with the LC-1
– are designed to work with unleaded gasoline. Using them with leaded gasoline
will significantly reduce the lifespan of the sensor. The reduction is directly
proportional to the metal content of the fuel. In most cases, a wide band sensor
will provide accurate measurements somewhere between 50 hours and 500 hours
with leaded fuel.
Drove mine on the street, tuned on it for hours in the driveway, made nearly 200 passes.. Still ticking when I sold the car. That was on SONOCO 118.
