For the cost of $47.50 I would replace it with a complete hot wire kit from Racetronix, at least you know what's in your car.
It seems for a stock car you might need to a spring cleaning (
http://www.gnttype.org/maint/basics.html) as one member has suggested.
I too have a stock engine and if you read my sig of having a ScanMaster, Racetronix hot-wire kit with fuel pump, Full Throttle Commander chips w/ matching 60# injectors, adj. fuel pump, and triple pod gauges w/ Auto Meter A/F gauge, oil pressure gauge, vac/boost gauge, and a Kenne Belle rear seat brace.
Your original fuel injectors definitely needs to be professional clean, or just replace them. I asked some members who claimed to go with the 60# injectors as this will cover any or many upgrade mod on your engine. Personally, I might want to change my injectors from 60# to 36# or 42#.
One major change you will need to do is the nylon cam gear sprocket, and with that many mileage you are taking a chance of having pieces of nylon teeth flowing around your oil pan, and blocking your oil pump pickup.
A minimum of having the following: oil pressure gauge, vac/boost gauge, air/fuel gauge, and a fuel pressure gauge to set the adjustable fuel pressure regulator as these will help you in tuning the engine without going to a lean condition.
