will not shift from 1-2
87GNcospg
Send your Donations
my fathers TT/A will not shift from 1st to 2nd at wide open throttle. it will go on until it hits a rev limiter at about 5,500 rpm. is this a problem with the govenor?
also, the car seems to wind up a little too much in first gear when you are just cruising around and get into the gas a litte bit.
is the gov. accessible from the outside of the tranny? is it something i should have a shop check out or can i take care of it myself?
i think the gov. is the giant button looking thing on the passenger side of the tranny. am i correct?
Remembering a previous post of your, did you relace the TV cable? Was it the same length as the old one? Is the TV cable set correctly? When mine wasn't it wouldn't shift into 2nd and 3rd untill around 4500 RPM.
me and my dad spent an hour adjusting the cable on the t/a and it made no difference on the 1-2 shift.
