I am swapping my factory coils to the moog 5658 and am wondering if the approach I am planning will work. Looking for some real world experience from guys that have done it this way. This has worked for me on many other cars but will be the first time on a G body.
Car will be up on 4 floor jacks(front and rear).
-Remove front shocks.
-Remove sway bar links.
-Loosen lower ball joint nut. Do not remove...leave just enough for the joint to pop (after a good hammer wack)and still containt the spring.
-Support lower A arm with floor jack after the ball joint is loose and remove nut.
-Slowly lower A arm and remove spring.
Install is the above in reverse. My only concern with this approach is being able to compress the new moog spring enough so that I am able to get the ball joint into the spindle and get the nut on it. Has worked ok on A body, F body...etc, but first time with the G. Common sense says its all the same, but one never knows so any advice and/or recomendations would be appreciated. A body cars are heavier so compressing the spring was never a problem. F bodies were the same. The car is an 87 T.....and Im not sure if there is enought weight on the nose to do this.
Thanks guys.
Thanks guys.
