SignUp Now!17X7 4" backspace fronts and 17X9 5" backspace rear. Will this combo work on a 1987 GN?
That is the wrong backspace for front and rear. You need to find out if any modifications will work. I believe a 5" backspace in the rear with rub the frame rail. Might be able to use a spacer and would def need longer wheel studs. Not that bad of a swap at a good shop.
my setup is 17x8 4''bs 245/45s tires in front 17x9.5 4.75bs 275/40s in back with no problems:biggrin: at all.And with a 10000000% oem 20 plus year old suspension
Whats the selection of tires like at that size?
here is one picture i have
