Wilwood front brakes
gnloyalty8777
I bought these from a member and ended up going with baer instead cause i got a great deal on them. Everything pictured is included. Also have slotted and drilled rotors for wilwood brakes. Add 3% for paypal
$500 shipped w/o slotted rotors
$575 shipped with both set of rotors
$100 for drilled and slotted rotorsView attachment 153757
I posted the pics from when i bought them to save time and didn't mean to post them up. Its fixed now
interested.
what size rotors , will they fit with 15" rims?
do you know the kit # ?
How many piston are the calipers? And what size are the rotors?
Chris
They will fit 15" wheels. They are 11" rotors and they are 4 piston calipers. The kit # is 140-2508-B
So for 575 does the kit with two sets of rotors,and is the kit complete?
i cant figure out how to pm you,can you please text me 214-606-8779
yes you need to modify spindles , not that difficult saw off the OE brake ears and tap the existing dust sheild bolt holes to 3/8-24 unf , you shouldnt need to remove the spindle to do the mods
he gave the part # and the specific instructions and specs can be found on wilwoods site
http://www.wilwood.com/Search/PartNoSearch.aspx?itemno=2508
only issue i have is on this kit to clear the calipers they move the track width out .92" so id have to change my front rim to something with more backspace
if your rims can take the pushout its a great deal as list is around 750 before ship , and the spare set of rotors isnt bad to grab since they run about 1oo each for the smooth rotors
oh and if he doesnt have it . . youll need the line kit http://www.wilwood.com/LineKits/LineKitsProd.aspx?itemno=220-7056
Definitely a great deal. Running stock wheels now. Wonder how that will be?
