- May 27, 2010
Did you mean it won't seal on the vertical according to your picture. I'd be curious to see what your door gap looks like. I've used the metro stuff in the past and had success. If your doors are not sitting right on the body your not going to have a good time been there.It is a shame that the two times in the last 20 years the last set just recently purchased, that the rubber seals around the windows do not seal at the horizontal angles. I was hoping to not have to live with the wind noise any more. Paul is correct no window adjustment will reach the rubber at the angles. Padding behind the seal is not an option. The distance it to great.
