BlackBandit
God loves Buicks!
- Mar 29, 2003
I'll try and keep this simple and to the point. I'm curious what boost conditions people were operating under when they wiped there cams. I know additives get blames allot for the cam wiping but what about the fact that it's gotten exponentially easier to run more boost (thanks to our vendors
) As cool as that is I don't think I've ever seen anyone post about using a stiffer spring on a new engine because they're planning on running high boost. If you think about it the stocker ran 15 psi so it took about 15 pounds off of the intake spring rate (while under boost) and probably close to 30 off of the exhaust. Now if you turn the wick up to 25 psi your basically reducing your intake spring rate by 25# and the exhaust by (total guess) ~40-50#. That's allot less pressure coming over the nose and usually that happens at higher rpms when the lifter has the most inertia the spring needs to overcome. So please poll up and lets see if boost can be linked to wiped cams.
Edit:I forgot to put it in the poll but if you don't mind post whether you had intake or exhaust valves wiped or wiping.
