SignUp Now!Do the 4.1 blocks have the same issue with lifter bore alignment causing wiped cams on 3 exhaust? Has anybody had this happen with the 4.1 castings?
Since 1986 I have worked on hundreds of turbo Buicks and have yet to see an original engine, even with almost 200k, wipe a cam?
Certainly if Buick had screwed up lifter bore alignment, I would have come across at least one?
The few wiped cams I have seen were aftermarket and had problems for various reasons, mainly Mobil I.
There was a lot of bad cam blanks in the mid-90's that trashed many engines, not just Buicks.
Has anybody acually seen a wiped cam on a 4.1, regardless of cause?
The Elgin cam in my 4.1 isnt wiped yet, but it is in the process of destroying itself. I didnt have any problems with it though until the truck flipped over.
Good to see theres a few buicks in the Burque!
A.j.
im still running flat tappets in most of my motors just cause there cheap, the grinds are plentyful and well, i drill my lifters..... ive had very few problems.
Whats the worse that could happen if you leave it? it wipes and you have to add the roller? atleast you had fun for i dunno...... 20K plus miles maybe? gives you time to save for that pricey 800 dollar kit.
A.j.
A.j.
Drill lifters?? Could you explain...
The worse that can happen is the wipe cam material takes out the crank and bearings and your paying for a full rebuild again.. For the 500.00 extra between the 2 cams I think its well worth it to go with the ROLLER!
