Wires behind AC compressor
klmnla
Watson LA
Is this the correct connection for the blue wire with the green connector?
I believe the gray wire is the fuel pump bypass, but I never was sure about the green connector and the blue wire.
The green connector is a tach connection. If the car has a tach in it, it is likely connected via the blue wire.
You are correct about the gray wire.
RemoveBeforeFlight
