Wiring Connection Identification???
PaulRV6
I must have mis-labeled a connector on the end of the wire harness towards the front driver side. It is a 2 spaded female black connector that I had labeled compressor but I can only find one connection on the compressor which is filled.
Any help would be appreciated.
paul
Well lets see.....everything comes out the front driver side.
Alternator
MAF
Coolant temp sensor
Cam sensor
Crank sensor
IAC
Water temp
Wastegate Solenoid
Fuel Pump jumper, not connected
O2
TPS
Compressor relay
MAT sensor
Alternator - NO
MAF - NO
Coolant temp sensor - NO
Cam sensor - NO
Crank sensor - NO
IAC - NO
Water temp - NO
Wastegate Solenoid - NO
Fuel Pump jumper, not connected - NO
O2 - NO
TPS - NO
Compressor relay - MAYBE, Is there another connection, two?
MAT sensor - NO
I only find one electrical connection on the compressor, there is a switch in the AC line but that is not it. That has to be more?
paul
Yes there is 2 connectors on the compressor. Does the one you have have a little resistor btw the two spades? If so that one plugs near the bottom of the compresser on the side.
It does not have a resistor between the blades but it is a double spaded connector. So it does go to the compressor? Can it be connected while the compressor is in place? Do I need this resistor? Thanks
paul
What color are the wires going to it?
Might make it a bit easier to find. :)
Well RASTAZ has confirmed via link to CASPERS that it is for the AC. Now I just have to check if the diode is in place.
Thanks for the help, this group is great!!!
paul
