87 Buick Limited
TE 44 with Blue Tops
Terry Houston downpipe
Turbo Tweak Chip 93 Octane
LT-1 Valve Springs
Hot Wired Pump Walbro
3" LT-1 MAF
Translator Plus
Cold Air Kit
Volt booster
I have pulled the trans pan and checked the governor spring, It is still intact. Just does it when you turn the car really hard.
Thought it might have been spark knock retarding the timing at that point, but turbolink shows no knock. Trans shifts hard under any acceleration on 1-2 and 2-3 shift, except on occasion when rpms are really high. Don't have aftermarket tach and the factory one is not accurate as you know. I would guess it somewhere around 5000-5300. It seems like an electrical or ignition problem but haven't figured it out yet. All the #'s on Turbo Link are within
specs. Any HELP from the experts would be greatly appreciated. I have really learned a lot from reading the forums but haven't seen anyone with a similar problem.
Thanks in advance
Robert ô¿ô
