fullahotair
- Feb 26, 2002
HI guys,
I thought i would take the car out today for a spin, and immediately noticed it won't shift out of 1st until 4,000 rpm +/-, and 2nd until 3500-4000. That is under lite throttle or heavy throttle. Tranny is full. After i bolted on some drag radials earlier this year, I noticed that the shift points where higher, but wasn't too bad and I attributed it to the larger tire i had on the back. It wasn't anything like it is now. So while out, I moved the TV cable in both extremes, and it didn't seem to make any difference. I even set to factory settings (all the way in, and then plant the pedal and allow it to self adjust).
Also while i was out, from a stop, I loaded it up a little bit and took off, and it felt like it was slipping, because it didnt' really seem to **** and get like it normally does....
Anyone have any thoughts? or way to trouble shoot? Pump going bad?
It'll be put away for the winter anyway, so I got some time...
Nate
Nate
