Work 5758 turbo
YEEE85
I ordered one of these bad boys (Work 5857 hot air turbo) over the winter and I'm hoping to see it show up pretty soon. Is anybody out there running one already? How does it run compared to stock? I'm working on uncorking this engine with head and intake and exhaust mods too. It always felt like it wanted to fly, but needs to breath better.
Just got mine 9 days ago !!! Hoping to have it installed in a couple weeks after I get back into town along with 60# injectors, Chip & valve springs. YEE HAA ! :cool:
Could you post a pic or two of those headers? I like doing fab work.
I received mine in January and I'm very happy with the upgrade. Tip # 1 - Don't forget to apply some liquid teflon goop a few threads up from the base thread of the oil feed fitting. Tip #2 - If you're thinking of upgrading to an Alky system, now would be a good time to add a M15 nozzle to your turbo-to-intake adapter.
Nice! Looks like you have the same mods I'm doing only I'm going to run E85. Were you able to sneak the nozzle in around the driver side mounting bracket? Also are you running the nozzle straight in or at a 90- seems like a narrow space for the alky to atomize
Yes, I was able to sneak right around to the driver side, just past the turbo to manifold bracket.
Where did you get that oil SS braided line from?
I just installed my Alky Kit on my 85 and was told by Julio not to use the washer that presses between the nozzle and the neck between the turbo and intake. Instead leave it off and use some loctite. And making sure to use the correct thread tap so the fitting screws in.
I just started breathing a sigh of relief now that my knocks are under control. Lots of adjusting boost, timing, fuel on the TT chip....but it's coming together now.
