sixgun86gn
six offender
- Feb 10, 2002
I need help with a problem at WOT.The car stutters like its on a rev limiter and doesnt want to shift.Scanmaster shows wildly varying KR,especially at the top of first gear.Second and up KR is very minimal.O2s are reading low at any fuel pressure I set.FP right now is at 44# idle line on.Have tried changing TV cable setting and it does not help.I am running 93 and NOS booster.The heads are P&P,intake is too.cam is comp 206/206 ,rockers are T&D 1.65 ,fuel pump is walbro 340,and new filter.I have an AFPR and boost is 17#.converter is precision 9.5.injectors are new MSD 50#.Chip is from ramchargers and was ordered for the motor with 50s but otherwise stock with pt52.It was installed two days before the bearings spun,but worked fine.I installed the rest during rebuild,could this be the problem?The car never seems to get past 4000 rpm at WOT and it bounces there until it shifts.I have ordered an extender chip and trans + in hopes it will fix this problem.Also has a bad tip in stumble.I have use TEC to remove carbon from the cylinders after break in.Has anyone had this problem before?The springs SHOULD be new as the heads were ordered from Speed inc.This has me wanting to pull my hair out!
P.S. module is new also. Thanks.
