Well, I own an import based performance shop that does a lot of tuning (AEM, Motec, etc.) We do a lot of AEM installs and tuning here and wanted to give the AEM a try in my 87 GN. I am just going to make a Plug and Play harness for the EMS, so that no wires have to be spliced. Would anyone else be interested in something like this??? Here are some of its advatages:
Has all the same featers of Big Stuff, or FAST, but with these added features:
Boost control - It has a very good internal boost controler. All you need to do is wire in a solenoid (AEM or GM). You can do speed based boost, boost ramping, etc...
Nitrous Control / Water meth - Full programable nitrous control. Can turn nitrous map on via a certain boost level, speed, etc.. Just set the paramaters and go. This can also be used with water/meth injection. What we do is setup a car for a base pump gas tune, then use the nitrous map for boost increase, timing increase, and fuel adjustments. BUT the good thing about this system is that we run a pressure sensor inline with the water/meth system that monitors the pressure to make sure it doesnt drop (run out of meth, pump going bad, etc), if pressure drops, the EMS will automaticly switch back to the pump gas map and bring down the boost, timing and fuel. This makes the water/meth kits almost foolproof..
I thought of making a kit for the GNs with the boost solenoid already pre-wired, along with a MAP sensor, AIT sensor, and a few other options.
The AEM kit will cost the same or LESS than the others, with a lot more tuning capabilities...
I plan to do a tune for E98 as soon as I get the system running. I will post my results as soon as I have them. Please give me some feedback, questions, etc. I truley think this would be a great EMS for the GN's.
Tim Robards
RRev Motorsports
Tim@rrevmotorsports.com
www.rrevmotorsports.com
Tim Robards
RRev Motorsports
