Yankee John
- Sep 17, 2008
When I got my Grand National, It already had a cold air intake on it with a K&N filter and stock MAF. I later changed to an LT-1 MAF. This set-up still put the K&N airfilter partially behind my radiator. Of course, Some of the radiator heat was transfered to the intake and the ATS reading on my Scanmaster was reading 20 degrees higher than ambient air temp/outside temp.
Today, I put a 6" spacer between the MAF and the filter, thus putting the filter directly in front of the opening of the core support behind the driver's side headlights.
What a difference in temperature readings this made on my Scanmaster! At highway speed, The ATS temp reading is within 3-5 degrees of outside temperature. At in-town speeds (30 mph+), the Scanmaster reads within 6-8 degrees of outside temp.
This has got to help performance and efficiency! Does anybody know exactly how much intake air temperature influences performance and power?
You will also see in my pics that I had to relocate my Translator, Since the relocated filter took the spot were I had it mounted- I simply zip-tied it to my air filter!
Thought you would like to know!
John
John
