Turbo1dr
9 Sec Wanna-Be
- May 25, 2001
This car has been in a front end collision and the frame is bent. It will drive down the road but I wouldn't recommend doing that with the way it looks right now. It has a remanufactured engine that runs very good. The engine is clean on the inside and is quiet when running. It has the correct "BRF" code 200-4R Automatic Overdrive. The turbo has been replaced with a remanufactured unit. I do not know the mileage when the engine was installed. This car has not been modified or "hot rodded"....it's completely stock. It's optioned with a factory security system, power windows, power door locks, cruise control, A/C and T-Tops. The interior is in very poor condition due to being stored out in the sun. There is NO TITLE so I'm selling it as a parts car only. This car would make a great donor car for a "cloned" 82- 87 carbureted Regal!!!! Almost EVERYTHING you need to convert your 78-88 GM "G-Body" car over to a Turbo-Intercooled GN engine/transmission is there EXCEPT the differential...which has been replaced with a 7.5" unit.
DOES NOT COME WITH RIMS YOU SEE IN THE PICTURES.
MAKE OFFER
VIDEO
MAKE OFFER
VIDEO
