WTB - 2 fuels socks for Reds xp pumps.
Looking for 2 new in tank fuel pump filters ( the ones on the inlet side of the fuel pump in the tank )
Let me know what you have.
Sent from my SGH-M919 using Tapatalk
The manufacture spec for the FS29 does not match what Red uses. It is much larger than the ones I have here. It is shown by the many pictures of the sock online. It may push onto the pump, but its not correct.
Can you please post the part number of the one red uses? The FS29 is what I came up with when I needed to replace mine on his double pumper. When I compared them they were the same size and fit of the originals I took off. So do you meen the flow numbers are larger or better filtering? Thanks,Mike
I do not have a part number of the sock Red uses on his fuel pumps. If the Aritex is the same size as what you removed from Red Double Pumper, Airtex is wrong with there specs on sock size and every picture is wrong which is very possible. See picture of airtex and reds for comparison.
Airtex ..........................................Reds
I have 6 stinking pumps I'll put my gauge on them and measure the part that this stupid filter fits onto.
I do see that two of the pumps have a MUCH larger fitting than the others.
And those are the ones that I need.
I did already order the ones Paul put a link to. I'll post up my findings any which way this crap goes.
Also if anyone does have these filters new and are sure that they fit Red's pumps I'll buy an extra set.
I just compared the new sock (Paul's link) with my old sock and they are identical, accept for the dirt content.
yeah baby.
Fuel tank is going in today
