WTB 60-1 Actuator
czimpel
Boost...gotta get some!
Looking for an actuator for a 60-1 turbo. I'm guessing I'll need the high psi one since I'll be running around 24 psi boost. Price shipped to 56379 if you have one.
Thanks, Cory
Thanks, Cory
If it's an e cover it will take any actuator from any e cover. New $100 shipped for a high pressure. Used $55 shipped. Not sure if I have any used high pressure actuators around though. A true 60-1 uses a different compressor cover than an e cover though
It's the 60-1 I bought from 87chrisss. Not sure about the cover. 3" inlet 2" outlet. If you have a used one I'll take it, otherwise probably have to buy the new one. 87chrisss said he used the stock one with only one bolt, is that ok to do? Also, even if that works, would it be able to be used for the 24 psi I'm shooting for?
I honeslty use a stock WG and i just bolt up wherever i can, if its one bolt that allows me then that what's holding it in. If you have one already Cory just use the one you have take off the little arm and cut it 1/2 inch back that will allow you to have more boost. No need to buy another one, Here click in this link and it'll help you with picture's etc.. I stopped buying actuators, i have one that ive used for probably two years on 3 different turbo's always have a mounting issue so i just do what i can with what i have not that serious wont damage anything one bolt should atleast bolt up and as long as it's secure you should be fine.
http://www.gnttype.org/techarea/images/Adj_wastegate.JPG
Sounds good, I just like things done right, but hate to spend the extra money on one. Thanks!
Thanks for the link, that helped a lot.
