WTB: GN Daily Cruiser Near OH/MI/IN/KY/PA/WV Area
flipmo
"Come Correct - Boosted"
Hi All. Well, I figured I'd just throw it out there versus searching Ebay and Autotrader religiously. I'm currently looking for a daily driver 1986 - 1987 GN, T-Type, Turbo-T, Turbo Regal to drive the pants off everyday. Car can be bone stock or have bolt-ons. For the right price (you know my style) this could be a very very easy transaction. That's if you really want to sale. I'm simply looking for a very nice daily car that's not beat up w/decent paint.
Was considering a Turbo-Bike -vs- a Turbo Regal for daily driver and the Turbo Regal convinced me.
What you have? If I decide to not buy yours please don't beat me up :biggrin:.
flip
87 for Sale - T Tops
Here is what I have. I was going to put up for sale anyways. I just have not had time to do get it the way I want it and unfortunately I live in Michigan. (do I have to say more?) Items that don't work are: power locks and AC. AC has been converted and it holds the freon but I think there must be a fuse or relay switch that needs to be replaced. Car has 36,300 miles. I have legal affidavit representing actual mileage from previous owner. I have plenty of pictures if you want to make your own opinion. I am located in northern suburb of Detroit. Since you asked I thought I would post it here before placing as separate thread. Asking price is $17,500.
Engine
· Rebuilt engine at 32,500 miles (have receipts)
· .41 over bored and balanced
· Ported iron stock heads
· Ported intake
· RJC power plate
· RJC Bullet Proof Head Gaskets
· Cam 10/10 grind
· T&D Roller rockers
· 50lb Precision injectors
· 62 mm throttle body
· 60 mm Precision turbo
· Heated 4-wire oxygen sensor
· Tinman cold air kit
· Headers
· Duttweiler neck on stock intercooler
· Hot wired fuel pump - Turbonetics
· 3” Stainless Steel downpipe with 38mm external wastegate (GN1)
· 3” Stainless Steel catback exhaust and test pipe (GN1)
· Turbonetics boost controller
· Progressive Alky injection system
· Performance chip
· Scanmaster 2.1
· New battery (purchased 7/08)
Suspension
· Tubular upper and lower control arms (UMI)
· Rear air bags
· Front frame and connecting braces
· Slotted and drilled front rotors
· Vacuum brake conversion
· Larger rear drum brakes
Transmission
· Upgraded 200r4 (bullet proof) (have receipts)
· Modified Art Carr cast aluminum pan
· Trans cooler
· 3.42 posi rear end
Interior
· GNX style dash
· New steering wheel
· All plastic perfect except small cracks in front speaker grills
· Seats are very good to excellent
· GNX style headrests
· Overall interior 9 out of 10
· Knock gauge
· Power windows, locks, truck release
· Concert sound
Exterior
· GNX louvers and wheel flairs
· Body is rust free with the exception of front lower doors that have minor rust
· Weld pro-star wheels in perfect condition
· Tires front 215/65/15 rear 275/60/15
· T-Tops and weather-stripping very good no leaks
more pictures
Here are some more pics. I guess this could be considered a driver for a guy that had a stage II GN. PM me if you wnat more info.
Tony
looking for gn or t-type
Hey Tony you just cant keep away I know what you are going through talk to you soon take care and good luck .
Tony
Check your PM.
Hey big guy and how are you man? Yeah, kind of back in the saddle again here. I see you called and will give you a buzz later on today. I got 3 GNs staring me in the face (two within reach) and it's tough to pick the lesser of 3 evils :eek:. Many members don't surface until the weekend so I'm sure there will be more to present their cars for sale. But these are very nice!
Yet this is fun as I just gotta freakin decide.
flip
AffordableGN's Street Car
Sent PM.
This is the one!!!
Here is the small list of mods.
AffordableGN's 10 Second Street Car.
Air Conditioning & 200r4 with No Cage.
Girdled 109 Block
Forged Pistons
File Fitted Rings
Roller Cam
Double Roller Timing Chain
DLS External Oil Pump System
DLS Deep Sump Oil Pan
ARP Pan Bolts
Champion GN-1 Aluminum Heads Race Ported
T&D 1.65 Roller Rockers
ARP Head Studs
Cometic Head Gaskets
Polished Aluminum Valve Covers
Champion Intake Manifold Race Ported
Champion Fuel Rails
High Volume Timing Cover
Accufab Adjustable Fuel Regulator
Accufab 70 MM Throttle Body
Precision Plenum Ported
Champion 1” Plenum Spacer
Precision 85 Lb/Hr Injectors
Modded ECM for High Impedence Injectors
RJC Racing Pulleys
AC/Delco AC Compressor New
AC/Delco Alternator New
Full Throttle 4” MAF Pipe
Full Throttle Translator
Turbo Tweak Race & Street Chips
Siemens 85 Lb/Hour Injectors
Auto meter 2 5/8 Liquid Filled Water Temp Gauge
Auto meter 2 5/8 Liquid Filled Boost Gauge
Auto meter 2 5/8 Liquid Filled Oil Pressure Gauge
Custom Auto Meter Gauge Holder
H&R Poly Motor & Tranny Mounts
ATR Stainless Steel Headers
Terry Houston Stainless 3” Downpipe for ATR
Innovative Wide Band 02 Sensor
Casper’s Hot Wire Kit
Walbro 340 Fuel Pump
Aluminum Radiator
Dual Spal Fans
Transmission & Oil Cooler
Precision Front Mount Intercooler
Tin Man Cold Air Intake
Precision GT6776 Dual Ball Bearing Turbo
RJC Boost Controller
Aluminum Driveshaft 3”
Eibach 1” Lowering Springs
Bilstein Rear Shocks
QA-1 Adjustable Front Shocks
Dual Air Bags
Moser 28 Spline Axles
Metco Adjustable Upper & Lower Control Arms
Brian Hoffer Full Billet Rollerized 200r4 Transmission
Art Carr CPT Billet 3200 N/L 9” Stall Converter
LPW Rear End Cover with Arms
Torque Tech 3” Exhaust System
Magnaflow Stainless Steel Mufflers
Kirban Rear Seat Braces
Seats Recovered by Jax’s Seat & Upholstery
Very Cold AC charged with R12
No Roll Bar or Cage
Best Pass is 10.43 @ 126 mph
Ran 10.43, 10.50, 10.59, 10.62, 10.63 @ Midwest Buick Challenge.
You know the price.
Let's work this out!
Jason
AffordableGN
check out -86 gn in ohio awesome condition-thread i talked to you on the phone. there are pics of the car on there now. 10 sec. daily driver.
Hey....
hey flip...don't forget me if you end up not getting another buick.....i'm still looking for rims for my 87!!! Chris
Hi Chris. I haven't forgotten and trying my best to pick the "right GN" to bolt them on :biggrin: :biggrin: :biggrin:. I guess you say I should have been sold them long ago, hmmm?
Well, if one doesn't pan out soon I'll give you a hollow for a quick sale.
My New Toy - PICs
Hi All. Well, thanks to everyone who presented their car for sale. After not immediately purchasing one of the ones currently available, I recently decided to just buy a turbo bike. So versus the GN, this is my new toy.
Turbo Hayabusa w/Fat Tire
All the Racing Engine Bells and Whistles "Laundry List Here"
Currently 300 RWHP and over 350 when set on Kill
My problem so far is that I can't keep the dorn thing on the ground :mad: :mad: :mad:. Even while pulling 3rd and 4th gear it want to pull a wheelie. Scared the crap out of me a few time. I'm gonna need some time to figure out high RPM throttle responses.
Thanks All
flip
whoa!!!....
Nice ride Flip!!!....take your time getting used to it! Now, about them rims and tires..... Call me! Chris 440-759-5907 Later!
