WTB Used set OEM Door Window Seals
tb3
elbows & a$$holes
I currently have new aftermarket hard as rock junk seals installed. Brand new OEM are too pricey for me right now. Does anybody have a set of these that are in decent shape with no rips/tears/dryrot? I need both sides. Car is a hardtop and its the seal that I have my finger on in the pic.
I dont think that you can get these seals out without them tearing as they are usually glued in and when you try and remove them they tear, so you may be stuck with what you have unless someone has a set of NOS ones laying around that they dont need. Unfortunatly I jsut used my NOS pair I had.
I'm hoping to get lucky I suppose. I've had luck removing them in the past with a new razor blade, but I know that doesn't always work.
Go with soffseal! I got a whole set of seals from them and I am very happy! Seals are nice and soft! I got my set including door seals, trunk seals, and window seals for $159. Not bad at all! Good fitment as well!
And you have no problem with wind noise? And is there a slight give in the window seals for the window to make a good seal like the oem? If so, I'll take your word for it and go for the soffseal. That sounds like a great price compared to what I've been priceing new. I'm scared to spend over $250 on a pair of seals that I haven't felt (for how soft or hard they are) till they show up at my door. I realise I may need to readjust the windows when I install good seals and I do know how to adjust. I was able to quieten the ones I have on there quiet a bit. But with a good quality seal on these cars, (and a non-sagging door), I know that I should have zero wind noise, and no leaks when I wash the car (with a reasonable water pressure).
Mike, I'm not sure what brand they are. The car was painted right before I bought it. I checked receipt from body shop, the bill was almost $4,200. And was probably worth it considering the amazing job they done and what all they replaced. However, they skimped on the door seals. I've tried softening them up by repeatingly wiping them down with fabriglide over a couple months time. But all I've succeded in doing was making them look newer and newer. :rolleyes:
