SignUp Now!Originally posted by UNDRPSI
However I do not understand how BS differs between a 8" or a 9.5" wheel as bs is the maximum allowable distance between the hub and the frame or closest contact point depending on tire diameter. If I were going to order the same wheel that is on the car only in an *' version I would not order the same bs due to how close it is to the frame. It also would sit to far under the car. I guess that is what you were referring to when ytou suggested that the wheel size made a difference.
