Alright don't flame me to bad. I also own a 3rd gen Camaro already and the talon is a turbo and stupid fast plus it's got AWD and posi for the winter.
Maybe if I am lucky someone will want to buy it or trade for something interesting.
This car is stupid fast and the best combination you can get 6bolt engine/ 5speed tranny/ 4bolt rear end. Anyone who know's DSM's knows this combo was only made for a 1/2 year in 92. EVERYTHING has been replaced, Engine/tranny/ CV's all have less 30K on them and work great. Engine has great even compression, tranny shifts smooth. Timing belt was just replaced this week! Anyway on with the good stuff. I put the cost of the part new next to it so you can see how much money is in this car.
I drive it everyday to work, 120 miles, and love it but I have other projects I could put the money in.
Early 92' 6Bolt Motor 4Bolt Rearend (Best Model) -Engine- Slow Boy Racing Stage 2 Engine Includes Eagle Rods, Ross Pistons, Celvite Rod + Main Bearings, ARP Rod Bolts $2300-500 core=1800
New front cover and water pump $250
Balance Shaft eliminator kit- $75.
1994 Cylinder Heads with ARP Head Studs + Multi layer Steel Head Gasket,$300
FP Green Turbo. Oil and water cooled, larger 8cm housing 730cfm $1500
Will run 25psi on the street on pump gas!!!!
Comp cams 101100 cams, slightly larger then HKS 264's $425
Sheet metal intake, 6 inch runners and larger plenum $125
Supra sidemount intercooler $150
Prothane Solid Motor Mounts $80
Ported Evolution3 Exhaust Manifold $300
ATR 3" Downpipe, 3" $300
Testpipe $20
3" Buschur Exhaust $500
2.5" SS O2 Housing $195
HKS Upper Intercooler Pipes (Thermo-Tec wrapped)$10
HKS Throttle Body Elbow $40
3.5" GM MAF $40
and 3.5" K&N Filter $20
GM MAF Translator $200
Walbro 255LPH HP Fuel Pump, $100
650 FIC injectors $250
Keydiver 650 chip, stutter box, no lift to shift $150
After base chip timing was recurved to allow the insane psi on the street. Buyer gets two chips.
Joe P MBC $45
Magnecore 8.5mm Wires $40
Autolite 3910 colder Spark Plugs $10
EGR Block off plate $40
RRE Catch Can $50
Coolant Bypass Mod,
-Drivetrain- Rebuilt Tranny with TRE Double Synchro 2nd $1000modified EVO3 Shift forks, Steel Shift Rails, Oil Screen, BG Synchroshift2 in Tranny, Redline
4-spider differential $450
Shockproof in center and rear differentials
Symborski metal shifter bushings $35
ACT2600 Clutch $400 TSS Heavy Duty Clutch Release Fork,
Stainless Steel Clutch Line $20
New CV axles $300
-Wheels, Tires, Brakes- 16x7 Rota Slipstreams (Bronze) + Locking Lugs $500
225/50 VR16 Kumho Supra 712 $320
-Suspension- Eibach Pro Kit Springs, $225
KYB AGX adjustable shocks $330
-Interior-
Pioneer 50w CD player and 6 pioneer speakers $150
Lo-Tek Dual Pillar Pod $40
Autometer Boost and A/F guages (black) $120
Momo Millenium Steering Wheel, Momo Race Leather Shift Knob, Momo E-Brake Handle + Boot $100
Summit Rear Battery Relocation Kit $40
-Misc- Removed Battery Tray + Charcoal Canister, Manual Steering Conversion, Removed AC System and Fan, Removed Cruise Control, Removed front and rear bumpers, Removed Backseat + Rear Seat Belts
Car weighs 28xx lbs.
Car has almost $14785 in mods (parts alone).
While I don't expect to get that back I'd take $7195 outright or maybe some type of trade for an 86+.
Testpipe $20
3.5" GM MAF $40
Joe P MBC $45
RRE Catch Can $50
Coolant Bypass Mod,
New CV axles $300
-Interior-
