Looking to do the valve springs on my motor as a spring project. Car has 27K origional miles and all stock internals. The usual bolt on upgrades - injectors, adj. WG, FP, 62mm TB etc.. I have no intention of changing the cam. The question is...what spring? I have had mixed response on the stock LT-1 springs or comp cams springs for a stick cam. Thoughts? I hear the comp cams are more precise in terms of open and closed pressure but I know they are a little heaver than the LT-1's so I don't want to wipe the cam after a short time.
The car is also an '89 TTA. Same spring as the g-body folks? I know the valve trains are different.
Thanks,
Brent
Thanks,
Brent
