Looking for some help on this. I have a new to me xfi with the Caspers adapter that I’m not getting a crank signal or rpm to. I get the cam signal and have spark but no crank or injectors. Have confirmed the crank sensor is working and sending a signal back to the ignition module and the module is sending the signal through the stock ecu wiring to the Caspers box. Would like any insight or help on this.
Also just checking to make sure that this is normal when you dump a new tune into it. (See picture for reference) but I would assume it should say updated 1792 of 1792 bytes but the message shows update 0 of 1792 bytes.
