XFI and nitrous
karolko
I have asked this question in the other forums, but this may be more applicable here.
With XFI, the poweradder option allows you to either use the factory injectors to add the extra fuel that the nitrous is asking for, or you can simply choose not to.
So here is the question: would it be easier to just purchase a dry nitrous kit and have the nitrous programmed into the XFI or should i go out and get a wet kit.
I like the idea of buying a nitrous kit. One, it's cheaper and secondly it would look cleaner inside of the engine bay.
Cal, you will be the one in charge of tuning, so what would you recommend?
How about you other guys with nitrous and XFI, what have you done.
Oh by the way, this setup is strickly for launch assist.
Thanks boys
If you had bigger inj I would suggest dry but 60's aren't going to do it...
Scott Wile
i have 83#er's. they are not too much bigger, so i do not know if they would work?
