XFI Error Code 2 = 8
TurboBuRick
Moderator
Staff member
Working on a friends car with xfi we are getting code 8 in the #2 box. Code definition says n/a. Any insight?
TIA
Rick
Next time, go to view/ecu fault codes and see what box is checked
Hi Cal, Your up early. :)
All the boxes are checked except the very last one.
Rick
Your looking at fault detection. Unless your running a flex fuel sensor, they shouldn't all be checked. Either way, your fault code is:
Injector duty cycle 100%
Did you turn the key off, then quickly back on? I have seen that set the code
Yes but if I remember right it came on while it was running. I'll see what happens next time. Thanks for the info!
Rick
That has happened to me a few times
Somehow it seems that fast likes a 3-5 sec key on before cranking...I just let the fuel pump prime(5 sec) then when it shuts off I crank to start...
If you turn the ignition off and then immediately back on before the xfi glows down, the computer sees a crank signal when the ignition switch comes back on. This in turn sets the injector duty cycle code.
It doesn't hurt anything, and can be avoided by waiting a couple seconds before powering back up.
Sent from my SAMSUNG-SGH-I317 using TurboBuick Mobile mobile app
