Any ideas what could cause this? Tried two IAC's both do the exact same thing... and appear to be working when you take one out... ground body... and hook back to harness and start the car.... (plunger moves).
Car throws a error code 128 while cranking or running.
IAC status is 15 with engine off... key on.....
Begin turning car over to crank.... 1 sec later (before engine even starts)... it has changed status to "12" which according to the help section in the manual.... is "thermal shutdown". As soon as the IAC status changes from 15 to 12.... it throws the error code 128 and the SES light stays on....
