psycho6cyl
Ponies Are For Lil Girls
- Feb 11, 2005
After seeing everyone mount their xfis in different places, I really wanted it somewhere hidden but still able to see the lights. I took the caspers extended harness and was able to plug factory wire harness into it behind.the glove box door. The wires are a tight fit,so I think I will have caspers make an extension harness between the caspers module and facory plugs. I then ran the wires underneath the control unit and back to the kick panel, where I wanted to mount xfi. Once mounted I hacked up factory ecu trim so it covers the xfi. The only thing left to do mark off on panel where lights are and use a dremel to cut a small window to see them. It seems really tight but I dont think I will be able to use top ecu trim piece. I may also cut it but im very happy how it all came out.
