NY Twin Turbo
All the good stuff.....Times 2.
- Dec 10, 2014
Has this ever happened to you guys?
I'll power into a cell on the VE map, maintain a steady load point and hold that cell location until it stabilizes.
Then I'll make the correction based on the O2 correction. And then it will be good.
Then when I enter the cell under the same circumstances as before it will show O2 correction again. I know this part is normal, because it may be a little touch lean or rich in the AE. But this should only be a brief moment.
This should again clear out and the cell should go back to almost no correction again. But it does not. It keeps on correcting even if the correction it is making provides the wrong AF.
Then I lift and return to the cell another time........and now it's good again.
What makes it get stuck on correction? I never gave this much thought because it's somewhat minor. This happens mostly when I'm trying to tune light load areas in the cruising area of the VE table. This area is important to me because I spend a lot of time enjoying nice long drives in the summer.
Until recently, I never gave this much thought because it's somewhat minor.
